KC reverse lights
KC reverse lights
Just installed a set of back up lights (KC 517). It only took about 25 minutes to get them in and the wires in place. Prob about 40 minutes counting the fine tuning. I was able to mount the relay inside and, thanks to jk-forum found the right wire to tap into. Thinking about adding the "switch kit" or just making one so I can turn them on if needed.
KC reverse lights
Originally Posted by GoodysGotaCuda
Looks good, relay is run to the battery. Correct?
bright
I'm not sure what I was expecting, but it's nothing earth moving. 100X better than before and more than enough to help you back down a trail (my use) or hookup a trailer. The optional switch would be useful, allowing you to cast extra light to the rear if you needed to work on something or help set up camp. Think I am just going to buy the pieces myself, saw a switch that looks just like the KC switches I have, at Advance Auto Parts, run power to it and plug it into the relay.
And yes 55 watt
And yes 55 watt
I had the same lights for a few years. they worked great for me. I hooked them up to a switch on the dash, i didnt tap into the reverse lights. not i have the ones built into the LoD rear. I may install the old lights to my rack in the back. angle them out to the sides a bit.
