KC Light wiring question....
Where are you guys pulling the wires through the firewall at to inside the cabin for the on-off switch? I took a peak under the hood and does not look like there is alot of room to play with. Thanks in advance.
firewall
I Drilled a 1/4 hole behind the glove box right next to where the heater hoses come in . There is a little flat spot there. And i put a little rubber grommet in the hole .
