KC light
Old 09-29-2012 | 01:15 PM
08RedRecon's Avatar
Default KC light
So I have installed a set of KC Slimlite Fog lights. Theya re currently tied into the toggle switch that came with it. It lights up and the lights do not. Here is a summary of my connections and what I have done to troubleshoot so far:
From the relay:
Yellow to battery
Black to ground
red/black to lights
Green to Load (toggle switch)
From the toggle switch:
Brown to ground
Green (load) to relay as stated above
White (supply) tied into yellow going to battery (between battery and fuse in yellow line).
I have replaced fuses on the white line. Believe my white wire touched the ground blowing out fise.
I bought a new relay but that didnt help.
I checked and rechecked both grounds
I tested all wires with a tester:
- white and yellow have power
- I have power at toggle switch
- When toggle is off, I get power only at red wire in relay
When toggle is on, I get a reading on all wires goin in/out of the relay
- I have no reading at the lights
it has to be a problem with the relay doesnt it?
Old 09-29-2012 | 08:31 PM
08RedRecon's Avatar
Any thoughts??
Im going to check the grounds again tomorrow
Old 09-29-2012 | 10:22 PM
Jeepster831's Avatar
Same problem with me. Fuses looked good going to the battery but I replaced them anyways. Problem solved
Old 09-30-2012 | 09:39 AM
08RedRecon's Avatar
Issue resolved, turned out to be a ground wire
