KC harness with LED pods
Old 03-26-2015 | 03:52 PM
phillipb's Avatar
Default KC harness with LED pods
I currently have the 6" KC Apollo lights with windshield mounts, and I'm wanting to switch to some LED pods. The lights both have the same connectors, so I'm wanting to just swap the lights out, but don't know if that's alright to do.
The KCs are here:
KC HiLiTES 150 - KC HiLites 6" Apollo Pro Series 100 Watt Long Range Lamp System with Stone Guards in Black - Quadratec
And the LED pods are here:
2-inch Square Cree LED Lights [70903] | Rough Country Suspension Systems®
What do I need to look for to see if its safe to just swap out the lights? I imagine the power and ground is the same gauge, but not sure about the relay or fuse.
Old 03-26-2015 | 05:08 PM
14Sport's Avatar
You're going from 100 watts to 18 watts. Everything should be beefy enough.
Old 03-27-2015 | 07:47 AM
MotoJeeper's Avatar
Veteran: Marine Corp
All you should need to do is replace the fuse with one appropriate for the pods you're using.
Old 03-27-2015 | 08:51 AM
phillipb's Avatar
Thanks for the replies. I assumed the wiring would be able to handle them, but just wanted to be sure. I will be replacing the fuse. Thanks again!
