KC 55w fog lights just causing problems, help please ;/
Sounds to me like there is a different problem with the wiring, like something is shorting out... it was probably doing that the last time they went out but you moved all the wires around to check them and you may have moved the wire that was shorting out without even seeing it. I would go back and make sure none of the wires that are carrying power (battery feed, relay switched (power side) and the switched lead coming back to connect the lights. It doesn't take much to short a line and blow a fuse.
You can test the theory pretty easy. If you have a multimeter you can ohm out each line... or if you don't you can try testing the circuits like this (just have a handful of the proper fuses handy.) Move the wires around, pop in a fuse if it pops again move the wires around on one of the lights then pop in a fuse and repeat until you find the problem. You can also grab another relay incase that one is damaged.
