The JWSpeakers of Tail Lamps
Old 07-13-2014 | 07:24 AM
rodi's Avatar
I'd be inclined to do a write-up if they worked. :\
Old 07-13-2014 | 12:41 PM
JDub23's Avatar
I've got these - they come in red (make sure you order the correct ones). LOVE THEM. Spend the cash and get the resistors and everything. You'll be glad you did.
http://www.rockridge4wd.com/ROCKRIDG...-p/rr-5002.htm
Sent while my wife wasn't looking...
Old 07-13-2014 | 02:06 PM
TopGunLB's Avatar
I've got these Pilots from Quadratec. I like them because they look stock but have full LED component insides along with resistors. Plug n play took 5 minutes to install.
Pilot Automotive Plug-n-Play LED Tail Lamp Set for 07-12 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Occasionally they will be on eBay in the $200-225 range. search "JK Pilot rear LED tail". There is a guy who sells each side seperately so be sure to read the description.
Old 07-13-2014 | 02:50 PM
AE33's Avatar
From: Los Angeles, California, United States, United States
I have the spyder tails. They work and looks great! Super bright led reverse. I'll post pics later tonight.
Old 07-14-2014 | 10:50 AM
Baddkarmaracing's Avatar
why don't they work? I like the idea also
Old 07-14-2014 | 11:16 AM
PBone's Avatar
ROCKRIDGE 4WD LED Tail Light Conversion KIT - FLUSH MOUNT 4" ROUND W/ RED LENSE - For Jeep Wrangler JK 2007-2013 2 & 4 Door
I like those. Pretty straight forward install?
Old 07-14-2014 | 08:05 PM
Offroad_Elements's Avatar
Former Vendor
These are pretty new, ORO LiteDOT JK Kits
http://www.offroadelements.com/oro-l...ngler-jk-2007/
Old 07-15-2014 | 07:27 AM
rodi's Avatar
I got the wrong posi-tap size, but the right one never hives with the wiring, so I only had a driver side working. And then it stopped. I tested both and the lights work fine.
Old 07-15-2014 | 11:06 AM
Former Vendor
Here's the thread for the SR-M back up lights.
I did these last October and they're still as reliable as the day they were installed. As long as you have solid connections and zip tie wires together, you shouldn't have any issues.
Contact me any time for forum member pricing
Rigid SR-M Back Up Light Kit | Offroad Elements
Old 07-15-2014 | 11:38 AM
duluthjk's Avatar
I have the Off-Road Only LED's. Even for a non mechanically inclined person like me install is easy and you don't have to cut or drill the body at all to install them. And all the factory sockets are left in their so you can revert to stock if you are leasing or sell the Jeep.
Off Road Only LiteDOT™ Plate Light
Quick Reply: The JWSpeakers of Tail Lamps
