JL Audio Stealthbox Question
Originally Posted by Hskr4x4
Retail is $599 from what lady said at JL, but I bet Crutchfield will have around $400ish in a few weeks
Originally Posted by ludski
Where do you guys put your amps?
I have mine on the tailgate in s box I made.
But thinking I want it somewhere new now.
In case you didn't see this, I created a video about a year ago demoing my sound system. I have a JL Sub. Every door was closed on my JK except for the passenger door.
http://www.youtube.com/watch?v=GsBFgX51V8A
Originally Posted by jkerr
I mounted 2 stackable Alpine Marine amps under the passenger seat. I had to modify the seat rail a bit to get both to fit. One amp will fit there without a problem. The closer you have the amp to the battery the better.
YouTube Link: http://www.youtube.com/watch?v=GsBFgX51V8A
I've seen some folks put the amps in the rear storage bin. I know two Alpine amps will fit there no problem. You just have to make stand-off legs that will level them out. The bottom of the bin is rounded on the edges. I didn't like having the amps so far from the battery, which is why I mounted them under the seat. Huge power lines has to be run to keep voltage drop to a minimum.
