JK rear light wire code
hi, have a 2015 wrangler Unlimited… bought a chinese version of the anzo LED and it didn't work well…. LEDs out, inconsistent ….so, for now, bought a CREE 3157 LED and put it in …. it works great, stock housing of course but i do need to put in the 50W 6ohm resistor to correct for the flash rate now… i actually like the faster rate but the system warning light in the dash board is annoying so….
quesiton is, there are 3 wires that go to the bulb and i figure the black is ground BUT …which one is the one going to the turn signal/flasher element…. the white/purple or the white/yellow wire ? i guess i can cut one and see if it works when i put the resistor across but…. 50:50 chance but … if i get an answer here, i'd be 100% right the first time...
thanks,
jR
2015 JK unlimited, Guadratec LED headlight,...
thanks,
jR
wirings for turn sig/stop lamp
ok, great, tnx, will tap that wire to add the resistor….
btw, were you putting in another center stop light ? i mean, the JK already has that LED center from factory above the spare ?!??
j.rho
j.rho
I relocated my license plate there and needed to tap the light for the license plate light.
LED , load resistor
