JK light bar?
#31
Something my brother in law and I are planning on working on this spring. It will be modular so that the small basket can be removed quick and easily if necessary. Has a similar look to the KMA fab design but the lights will sit lower, the basket will conect using factory mounting points for the hardtop and door surrounds. It can be used with the top off ( obviously) or the soft top on with some minor modifications to the soft top via a marine shop. Perfect for those with a 2dr. and a need for a little extra storage space on longer than a day trail runs or camping trips.
#32
I am pretty sure it is made out of metal, but on all of their other bars it says it has a max of 4 pounds total, so I would think this would be the same. From their webiste:
The CARR Light Bar / Rota Bar can hold up to 4 lbs of lights, so depending on the size light you are installing will depend on the quantity the bar will hold.
#34
Yea, I emailed them to verify it on this product specifically just in case, like you said 4 pounds is less than just 1 light sometimes.
#37
Sponsoring Vendor
Off Road Evolution Rep
