JK Dash Install Kits? only Metra?
I got a Metra kit for my 2012, and its pretty crappy. I used the cage mount style, and the deck is sunken in way deep into the hole. You can't use the ISO mount pieces on this install, can you? I would like my deck a lot more if it stuck out flush with everything else so i can take the faceplate off.
anyone have any other brands they have used which are real clean?
That's the only kit I've found and it's a total pos. I'm probably gonna end up building my own.
As for a wiring harness the only one I've found for a 2012 was http://www.crutchfield.com/p_127C2RC...e.html?tp=3486
