JK Angel Eyes??
Old 11-04-2011, 07:59 AM
  #21
R0B0CON's Avatar
Default other led options
superbrightleds.com has some really inexpensive "Angle Eyes" that are 12V ready (no inverter required) if you don't mind a little more dis-assembly/assembly. down side is they don't list any in 7" diameter, only 60mm, 80mm, 100mm, and 120mm (up to 4.7 inches) and the light diffusers they have available only go up to 100mm.
Old 11-04-2011, 08:17 AM
  #22
JeepNoob10's Avatar
Originally Posted by ludski
so i did these in the past.
what i got in the box was:
2 inverters
2 halo rings
you attach them to the driving lights (orange lights)
and they work as a blinker or you can just use em to be on whenever jeep is on. or whenever lights are on.
you just attach the inverter to the ring. and attach the other end of the inverter to the power and ground source.
So whats actually involved in the install other than wiring? Do you take apart the housing and put the rings in and if so how NOT easy is that to do?
Old 11-04-2011, 08:31 AM
  #23
shhmack's Avatar
There is no inverter. They hook up just like any 12v thing would. I have them on my challenger, and though they look incredible, I would never get them again. They just don't work right, and keep going out in sets of threes. Plus u have to crack open your headlights housing everytime u need to work on them. But they do look great. If u want them, check out Advanced Automotive Concepts.
Old 11-04-2011, 08:36 AM
  #24
greglaw's Avatar
I like the look and am doing something similar to the bed liner grill I am working on.
Old 11-04-2011, 08:39 AM
  #25
shhmack's Avatar
To install, u have too take out your headlights housing and get it open. There are several ways to do this, I baked mine in the oven for like 10 min. Or u could cut them open. Then install the halo ring in the light with silicon and drill a hole for the wire. Then the fun part, getting it back together airtight.
Old 11-04-2011, 09:25 AM
  #26
Southern Girl's Avatar
Looks different but seems like a hassle....I'll pass...
Old 11-04-2011, 11:42 AM
  #27
Sapper12b's Avatar
yeah hassle .... might have to reconsider
Old 11-04-2011, 11:43 AM
  #28
rubi3's Avatar
This kit doesn't seem bad.
hxxp://www.ebay.com/itm/310345309403?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1438.l2649
Old 11-04-2011, 11:50 AM
  #29
JeepNoob10's Avatar
put housing in oven. (so the caulk loosens)
take apart housing.
put in halo ring.
sharpie 1 side of the ring. so it doesnt get weird reflection stuff going on.
glue ring in place.
reseal housing.
wiring.
done.
Cool. thanks!
Old 11-06-2011, 05:04 PM
  #30
greglaw's Avatar
This is what I am doing for day time LEDs.
ID:	233438   Click image for larger version
ID:	233439   Click image for larger version
ID:	233441   Click image for larger version
Quick Reply: JK Angel Eyes??
