J W Speaker headlights........... you need these in your life!!!!
#41
#42
They have yet to respond to my question about this but generally vendors do not include a true harness they come with a pigtail that does not have the capacitor inline to prevent the flickering. So to answer your question it will plug in but it wont fix the flickering. If you want to fix that you will have to buy a true harness or make one.
#43
I have a 2011, but they are idential to the 2012 for the bucket design. You are not required to grind the mount. What they are talking about is that the airbag sensor sits horizontally and there is a small shelf below it. The self was not present in the earlier models, that is why they could rotate the sensor with ease. It was added in 2011 and 2012. You can either grind off the self as some have done, snap it off with some needle nose pliers. Or what I did was just loosen the nut holding it on enough that the sensor can slip over the lil shelf, rotate it, then retighten the nut.
#44
Yes of course things have changed. I have installed them on my 2011 and also on a friends 2012 (after he saw mine) and can tell you the bucket design and location of the airbag sensor is identical for both years.
#45
#46
At that price, Ill be building my own as well. Looks fairly straightforward, male H13 to tap into stock control to relays with leads from battery, then two H4 females for lamps. I wouldn't think I need any diodes with this?
#47
Add an inline fuse, some 12 gage wire, acouple crimp on lugs, and some heat shrink and youre good to go. Total materials is probably around 40 dollars.
#48
Thanks, I love electrical projects! I already have most of the parts on hand. Awhile back I added Roundeye lights to my old FJ40 and bought the harness. Seems pretty much the same so I'll use that as a model. It did make quite a difference with those lights...dangerously dim beforehand. I don't really need the JWSs to be brighter, but I'm thinking a constant voltage is probably better for them... may make them last longer.
#49
Here is a quick DIY on making your own headlight harness.
Ensure you get 40A SPDT relays, that way you can connect one headlight to 87 and one headlight to 87a. I got mind on Amazon cheap. They may not be as high quality as the Hella relays that others use, but really a relay is a relay. If it goes bad I have spares.
amazon.com/AGT-Relay-Harness-Bosch-40AMP-HRNS/dp/B005HFYE1O/ref=pd_vtp_e_4
#50
