J W Speaker headlights........... you need these in your life!!!!
#21
Yes, I have a 2011. Rotating it 45 degrees will not affect its operation.
#22
So tonight I installed the JW Speaker LED head lights but the driver's side head lamp flickers to the degree that the passenger's head lamp light is totally still and doesn't appear to flicker as the driver's side does. Is this the problem when installing these LED lights on our JKs? If so, does this have a solution?
Thank you in advance for your help.
#23
#24
The headlights or the harness? Rebel offroad is a vendor here that sells the headlights. They can be had about 100 dollars cheaper though if you look around.
Headlight harness can be found at Susquenna Motorsport, Daniel stern lighting, 12 volt guy, or ebay.
#25
Former Vendor
Both are in stock and ready to ship.
(Plug and play referring to the wiring, on the JW their is trimming required in some Jeep model bezels as mentioned in this thread.)
#26
Every set of JW Speaker and Truck-Lite we sell comes with appropriate harnesses making them plug and play.
Is the harness you sell a true headlight harness with 2 relays (low beam, high beam) or is it just a H4 to H13 pigtail? Sorry but I couldnt find the info on your website.
#29
I read on another post that you could use an additional headlight ring and avoid the cutting / trimming. I tried to get a p/n for this headlight ring - any one know?
Thank you,
Alex
Thank you,
Alex
Technically they are not plug and play since you have to trim the bezel, rotate the airbag sensor, and intall a relay harness. But still very very easy.
#30
Really trimming the headlight ring is really easy with a dremel, takes about 30 minutes.
