Issues Starting
Issues Starting
Earlier this week I went to start my Wrangler and it clicked but wouldn’t turn over. Nothing left on in the vehicle, had not had any issues starting previously. Hooked up cables to get a jump and was reading 12.0 volts. Had it hooked up for 10 seconds and fired right up.
Drove fine the rest of the week, no issues. Get in this morning and the same thing.
now the only thing I noticed each time was the clock on my radio was off by quite a bit once I got it started up.
Taking my battery to get tested now, but if the battery is fine what could be causing this?
Alternator on the way out perhaps? Even try fan belt if you have not changed it. New belts when they slip are silent not like the old ones that would squeal. But most likely battery as they have a habit of simply going without warning.
