iPhone/iPod Mount - based on Griffen TuneFlex
I've been using the bungee for a couple of weeks now, even wheeling it stays put. Just make sure you use the smallest bungee you can get - mine was in a package of several different sizes at Home Depot. You can barely even see it unless you look behind the Tuneflex cradle.
Also, to note, the aux jack on the base of the tuneflex is a bit sensitive. Make sure you have decent clearance to plug it in so as not to screw up the jack.
I actually went and bought a "right angle" 3.5mm stereo plug to connect to it. The straight plug put unnecessary stress on the jack.
