IPF Lightbulb Replacement - Help!
I have the Jeep Wrangler JK (2007-2012) Head Lamp Conversion Kit (920HJKK) installed in my JK, and just had a bulb die on me. It comes with "IPF H4 Super J Beam 55/60 watt bulbs", and I'm wondering if there's any other bulb I could replace it with? (i.e. something I could pick up at a local auto parts chain). Are all H4 bulbs created equal (aside from wattage)?
Originally Posted by Ryan0260
How old is the bulb? If its less than a year it is under warranty and they should send you a new one
Originally Posted by blue project
Any H4 lamp will work. I have the same headlights and run the silverstars sylvania ultra's. A bit pricey but cheaper than the IPF lamps.
I installed the sylvanias lastnight, since timeliness was important (I don't need another fix it ticket from CHP)... They're... Ok. I installed just 1 at first so I could compare to the IPF bulb, and the IPF one is better, IMO, hands down. The sylvanias have a slightly yellowish look when compared to the IPF's.
Originally Posted by Bucko
How do you mean, better? Are the IPF's are bighter or is it that the Ultra's are yellowish? I originally bought the IPFs with the Ultras, so i have no comparison
except to stock.
except to stock.
Exactly. It's the color temperature that made the IPF look a lot brighter. I just made a nighttime drive all the way from San Diego to OC and i also noticed that the light from the IPF bulb is more diffused than the Sylvanias, and actually the high beams are very different - the Sylvanias put out a much "higher" high beam as far as the angle of projection goes. I'm starting to get used to the new bulbs, but if I had the choice I still like the IPF's better.
Take it from me...
For raw output, get the Philips XP +80%. And I installed the new Silverstar ZXE bulbs and they have a nice crisp white light in my girl's JK. The IPF blues are just too blue and don't put out as much light as the Ultras. I swapped out the ultras for the ZXE yesterday on her Jeep, and the ZXE put out just as much light and are whiter.
But the disclaimer says that the ZXE will not last as long as a conventional bulb. I say go with the Philips XP bulbs and you will not like the color, but the output is GREAT.
This always made me curious. People like the HID color temps of the cool blue hue. However, the human eye can better use the wavelengths closer to the red frequencies (oranges and yellows). I don't know if a yellow tint would reduce eye fatigue as compared to the higher kelvins or not???
All the same, I would imagine that would only make a difference on long drives at night.
