Ipf or delta headlights???
I took the Jeep to the snow this weekend and the lights are flat out dangerous!!! I couldnt even navigate corners without slowing way down because I couldnt see. I did a search and couldnt find my answer so I will post.
Which will give me the better lighting, the IPF lights or the Delta Xenon lights. They are the same price at $150. What fogs will match these lights?
you may want to check out the Hella upgrade. It offers a plug and play wire harness that lets you run higher out put bulbs. The IPF upgrade is great but does not address the power to the lights wich can be hindered by the canbus system...It is a few dollars more but address this issue with a new wire harness and relays..full plug and play.....
Here's another question- Has anyone done the IPF lights and put in PIAA H13 extreme white bulbs as an upgrade? I would like to go xenons but I am doing the install myself (Not very good at this stuff) and dont want cheap chinese shit that will go out after 3 months, any comments on this set up?
Your definatley right! I did a search under this section only and came up with a bunch of info, not going Deltas.
Thanks again bro. I will call Susquehanna motorsports tomorrow. What makes these better than the IPF'S? I will ask them about the H4 bulb upgrade as well (Says it on their site) Appreciate your input.
Northridge is a sponsoring vendor and offer the entire IPF kit to convert..
http://www.northridge4x4.com/proddet...prod=IPF-920H4
it's a good price too!
