IPF 968 switch
I don't think you can just cut it and wire another switch. You may need to wire a new switch with some t-taps or something.
I have the 968's and the 900's and I would prefer a cleanly installed switch, but I don't mind them that much.
Those look just like my PIAA's...3-pin connector. red pos, black ground, white/yellow switched 12v toggle (for illumination-may not have it with those switches). Should be a cut crimp and plug in situation.
I did mine with a rocker switch mounted above the speaker.
Yellow- Power for the switch, splice into the factory lights or acc. wire.
I used the acc. power outlet wire.
Black with white stripe - Return power for relay, runs from relay to switch.
Black - Ground, run from switch to the body.
