Interior LED ligts
#31
Has anyone tapped the center lights into the dimmer switch? This way you can control their brightness? Can you do a quick write up, I was thinking of adding lights but I would like them to be dimmed like my dash lights.
#32
Thanks. I tapped into the illumination dimmer circuit off the HVAC wire harness (orange with white tracer, I believe) behind the center dash. I ran it through a switch so I have the option of turning it on/off as needed. They're not overhead(but thats a cool idea), I put strips of lights below each lip on the center console.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=450666"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=450667"/>
The "Zombie Lights" activate the red LED interior
#33
From what I understand its a circuit board, so you can't just swap in switches. That's probably why so many people are adding aftermarket rocker type switches in various places. I think daystar makes a switch panel that fits directly underneath where those factory switches are.
