Installing an Ammeter - Hunty
Old 11-23-2010 | 10:47 PM
hunty's Avatar
Smile Installing an Ammeter - Hunty
Hi Guyz
I have recently added 5 more 100w lights to my JK and was wondering how my alternator was coping, I also wanted to know just how much strain my winch was placing on my Alternator, battery and electrical system at different levels of Pull!
I now have 900w of light (Hi Beam) and according to my new Ammeter I am using 61amps out of a total of 160 (yes I got lucky and my jeep has a 160amp alternator)
To save you all the pain I went through - heres a couple of tips
1. buy a ammeter and shunt that reads up to 500Amps
2. if you buy off Ebay as I did and they don't supply any instructions or wiring diags then pls only connect the shunt between the battery neg and the jeep - eg disconnect the black wire from the battery and insert the shunt!
3.be very careful to connect the sensor wires to the shunt with the correct polarity - if you don't you will need to buy a replacement Ammeter with a few seconds!
Warning - Science content - What is a shunt - well (pls post up electronic guru's if you can explain it better) it is a device with a tiny amount of resistance (75ma) so if you connect a load - (in my case 900w of light) to a battery and you connect through a shunt the voltage that you can read at the battery will be (if the battery is full) 13.8v and if you measure the voltage after it has gone through the shunt it will be approx .006v less - this tiny discrepancy is translated by the ammeter and displayed (in my case) as 61amps. - sorry for the science content Jeepers - LoL - but i'm sure at 1 person wants to now!
So next time I go wheelin and use my winch I will be able too see how many amps it sucks down.
cheers Hunty
Old 11-23-2010 | 10:51 PM
shockwaveaz's Avatar
That is pretty cool! I like that. How much does something like that cost?
Sent from my EVO using Tapatalk.
Old 11-23-2010 | 10:58 PM
ronjenx's Avatar
Very interesting.
What is the draw when just driving with all the lights off?
Old 11-23-2010 | 11:06 PM
hunty's Avatar
Smile
Originally Posted by ronjenx
Very interesting.
Hi
I'm starting to compile a list - so far I know;
Hi Beam = 61amps
Drivers power window = 6 amps
I will update this with more info soon
cheers Hunty
Old 11-23-2010 | 11:07 PM
hunty's Avatar
Smile Ammeter - Ebay - Cheap
Hi
The Ammeter & shunt cost me $30us delivered to Australia
cheers Hunty
Old 11-24-2010 | 05:31 AM
Tiki Tim's Avatar
In this case a shunt is a known resistor value. What the meter does is measure the voltage drop across this known resistor value and if you divide the voltage drop by the resistor value you get the current (amps).
If you multiply the current that the lamps draw (61) by the voltage going to the lamps (13.8) you can calculate the true power consumption of your load (841.8 watts).
Old 11-24-2010 | 06:33 AM
MartinC's Avatar
Which is just over 1 horsepower!
Old 11-24-2010 | 07:00 AM
ronjenx's Avatar
Originally Posted by hunty
Hi
Hi Beam = 61amps
cheers Hunty
61 amps for the headlights seems like an awful lot. Are they stock?
I was thinking the headlights would be 20 amps or less.
edit:
oops! I assumed "Hi Beam" meant the stock lights only. You are including all the extra lights, too. Correct?
Old 11-24-2010 | 07:11 AM
azrwilkinson's Avatar
I beleive thats with all the light on, am I right?
Old 11-24-2010 | 07:23 AM
ronjenx's Avatar
Yeah. I reread and it must include all the extra lights. My misinterpretation.
Quick Reply: Installing an Ammeter - Hunty
