Infinity System Popping Noise - New Speaker Fix?
Buzzzzzzzz!!! Another wrong answer!!!
P.S. Sorry, I'm not trying to be rude or disresptful, because it's obvious you're trying to just be helpful. But what you're describing is not what is going on in this scenario and I rather not see others trying to diagnose their speakers when the speakers are not the source of the problem.
Unfortunately yes you are being rude but that's OK opinions are like assholes every ones got one , most factory system are way under powered and are not designed to be cranked for long periods of time , most times distortion damage occurs from under powered over cranked system,
{edited}
You have some serious problems with your thought process and seem to try to speak about things that you know NOTHING about.
You're right....people should be filing their voice coils since the things you described are normally caused by having an out of round voice coil on a speaker and have NOTHING to do with driving a speaker too loud. Ignorance is bliss and you are filled with blissfulness. Please carry on.
Just tell me one thing. How many factory audio systems have you designed to be able to support ANYTHING that you mentioned with some actual facts or supporting data?
{edited}
How does it feel to be the only one right on this forum?
When I first tried to help out on the thread i didn't realize it was going to be a pissing contest
so all I have to say is you win your bigger Dick then I am
ok... back on topic now.
try this: https://www.jk-forum.com/forums/show...y-sound-system!!!
All it takes is to remove the screws in the bass box and switch the plugs on the speaker then re-install. Its the cheapest test to see if this works for you like it did me. Report back if you can.
Good luck!
Good luck!
I guess you guys with the big dicks didn't see my post.
I replaced the entire Infinity sound system. JVC HU, JL amp/components/ sub. When I play CD's it's like being in the studio. When I play music through my phone(blutooth streaming) some songs pop, some are over driven, some are clear. I've tried lowering the volume on the cell phone and it helped a little but pops still happen.
Thanks
Hey All,
THanks for your input on this.
After reading through the comments I figured simply updating the speakers would be the safest option.
I brought the TSB to my local dealer and $100.00 later all fixed.
I would recommend doing this first and upgrading later.
Thanks!
http://project-jk.com/images/tsb/TSB_08-030-07.pdf
Thanks!
