Ignition Switch Circuit Power - Everblades Plz help
Im not electrically incline by any stretch of the mind. I got a set of everblades heated wipers and it asked to connect to a switch circuit power source. A power source that is hot when the ignition is on. I know there are probably other threads on this but can't find them. Can anyone help me locate this power source under the hood in a clean way.
I'm on the phone, so maybe searching will be easier for you. Look for the user ronjenx and search for something along the lines of "easy switched power source". It'll pull up his thread and it'll answer your questions.
All of that being said- if you are not electrically inclined by any stretch of the mind then you may want to just find a shop to take care of this for you so you don't burn your vehicle down (a very real potential).
Sweet, i think that'll work. Thanks.
Maybe ill keep a fire extinguisher near by. he he https://www.jk-forum.com/forums/imag...lies/wink1.gif
I've located a power switch source at the tipm
But now I think it would be cleaner instead of a second switch on dash to tie it into the defrost switch.
Anyone know the best way to do this or if it's even possible.
I did it!!!
If anyone is installing heated wipers. Let me know and I do up a write up.
I hit the rear defrost / mirror defrost and the heated wipers goes on as well
With no extra switches in the dash.
