i want to add extra back up lights
look in the write up section OR try a search of back up lights.
Here I did it for you. This is the way I ended up doing mine but not cut into the bumper. Hey its a start
https://www.jk-forum.com/forums/show...ht=back+lights
I know the search brings up a bunch. I hope this helps.
Back-Up lights
Turkeyfreer did a beautiful install into a stock bumper, pics and write-up was great. Although I don't have a stock rear bumper, I am following this example to do mine when I get home from the sandbox.
https://www.jk-forum.com/forums/show...k-up+light+517
Also attached is the wiring diagram for the KC 517 kit, which shows how to wire it up to work with either the standard reverse lights or with a switch.
Thanks, Bill
I found a write up that i am going to be doing soon . . . i really like the set up
https://www.jk-forum.com/forums/jk-show-tell-33/%2420-rear-light-mod-55448/
I am curious on your 50 watt back up lights. Have you looked inside the light assembly for any heat/melting damage? I used a higher wattage in a dome light once and things started melting and discoloring. I realize the back up lights are not usually on for too long but I just wondered. No problem with the lighting computer either?
