I need to run some power for accesories.......
And I understand one of the fuze slots in the fuze block is empty and I can wire from it to an auxilliary fuze box where I can hook up. Has anybody done this? I was thinking that it would be better just to run power and the ground to an auxilliary fuze box. Opinios of experiences?
and many thanks in advance.
If you're talking about a "fuze box" that also contains relays, then you can draw the control circuit power from the TIPM (fuse box). You would draw the load power from the battery. If it contains only fuses and you plan to run each accessory load wire through it, then I would draw the power from the battery to feed the accessories, not the TIPM.
