HUGE HID issues
Old 01-26-2011, 08:35 AM
  #31
Default Error eliminators
Another $.02.....Maybe the EE's are flipping the polarity? Can you easily remove them and test the system?
Old 01-26-2011, 09:33 AM
  #32
JK-Ford's Avatar
Originally Posted by blancolex300
Good point, however it is hard to check with a meter goin 65 on the highway........., and if it does pull the stay on bulls**t, then the meter it shall be!
Then I recomend that you wear your PPE.
Error eliminators
Do you know what electronics are on board? Just wondering?
Old 01-26-2011, 09:56 AM
  #33
Iskreem's Avatar
No to hijack your post but...
I have been running my DDM Tuning kit for about 3 to 4 months now with no problems and just this after noon on my way back from lunch I noticed I have no lights now. I waited about 30 min and tried it again and nothing. I run error eliminators, my fuse is good and I can hear the relay clicking when I change from low beams to high beams so it seems as like my ballast are not getting power from the BiXenon controller or the BiXenon controller is not getting power from the battery. I'll start with checking my connections on the battery then out of the controller any other suggestions??
Old 01-26-2011, 10:16 AM
  #34
JK-Ford's Avatar
Harness fuse? Keep us posted.
Old 01-26-2011, 10:55 AM
  #35
blancolex300's Avatar
What is this "PPE" that you speak of? Personal Propulsion Engine?
Old 01-26-2011, 11:00 AM
  #36
JK-Ford's Avatar
http://www.osha.gov/OshDoc/data_Gene...-factsheet.pdf
Old 01-26-2011, 11:29 AM
  #37
Yeah, I had a feeling it was something like that.
Old 01-26-2011, 04:57 PM
  #38
Iskreem's Avatar
Called tech support they didn't question anything and said they would send me a new control module out and he was pretty sure that should fix the problem. Should be here in 2-5 days....
Old 01-27-2011, 05:36 AM
  #39
JK-Ford's Avatar
Thank you for the update. Let us know if this works.
Old 02-06-2011, 05:37 PM
  #40
Update:
I troubleshot the problem down to a bad control module and called DDM last Monday. They sent me out a new module, and I installed it today. It seems to work fine, so I am hoping that the issue is solved.
Quick Reply: HUGE HID issues
