HUGE HID issues
Agreed. Although my thoughts on the computer are correct. This has been proven time and time again by other Jeepers trying to improve their headlights. I can not explain why yours took so long to think that you have a problem. Or even if that is the problem. The only way to tell for sure is with a good meter.
Without actually seeing how everything is wired it will be hard to say what the problem is. You mentioned direct to the battery, what did you hook up direct to battery? Perhaps you have a wire crossed up for the relay and instead of providing switching power to the relay you are providing constant power to the ballast?
Originally Posted by blancolex300
That wouldn't explain why they stayed on for 3-4 hours on Sat. night though. And why they would only go off and then on intermittently.
The PLC in the Jeep has control over the lights. Fault conditions can cause PLC's to do strange things. Also, a low output current to a relay could have cause it to stay pulled in. But, once released, would not be enough to reseal the coil. We can speculate about diffrent things all day. But someone will have to lay their hands on the equipment. And observe some hard facts.
I'm not familiar with the DDM harness, but have installed many HID kits. Is there a separate + switch lead wire that you need to splice in somewhere? or is it a plug-n-play with the switch lead tied into the stock connector?
If the wiring harness looks like this>
And everything is properly grounded/connected I guess it would likely be a computer issue. Maybe disconnect the battery and let it reset
runit3
This OEM connector then supplies the switching power to the aftermarket relay set-up. When you turn the headlights on, the OEM connector sends power to the aftermarket relay which triggers the HID ballast.
So aside from the OEM connector, you have the AM relay which has a fused link to battery and a ground wire. Then from there it is all plug and play into the ballasts and then the 2 connectors to the HID bulbs.
If the OP installed everything correctly (which we can only assume) then I would say whoever said the computer is the culprit would be right. Is there a capcitor jumpered in the relay? This could be the easiest fix to try first as it has solved many light flickering issues and other similar problems.
Also, a proper ground is really necessary in the system, make sure you are using a very clean and solid ground. It is possible for some reason the relay itself is bad and the coil is not collapsing when powered off.
My suggestion would be to swap out the relay (they are cheap enough at under $5 and it is good to have one handy) or try the capcitor jumper trick. The capcitor should go between the ground and switched positive terminals on the relay IIRC.
I think the capcitor I used was a 470 micro farad 35VDC electrolytic capacitor FYI.
I also want to add that this is very important. Not knowing your install or the specs of your system, the polarity CAN BE BACKWARDS!
Just because it is plug and play and clicks together DOES NOT MEAN it is right. I've seen the problem on Dodges where the polarity is backwards and this causes the ballasts to stay on even when powered off. If I were you, I'd look into this ASAP. Simple enough to do with a multimeter and you won't be running in circles trying to figure out what is wrong. When working with electrical systems, you need to know what is positive and what is negative and be sure that the aftermarket connectors are set-up the same way.
Again Dodge has been known to have this problem with the polarity reversed. The wires are easy enough to release from the clips, so I'd suggest flipping them to see if it solves the issue.
Also here is a pic of the way the capcitor attaches to the relay harness for those that don't ant to search:
So check 3 things:
1. Check to be sure you have a solid ground for the relay.
2. See if the relay is clicking at all, maybe swap relays and add a capcitor
3. Check the polarity of the wires, reverse them if necessary.
Installing a HID kit isn't always a simple plug and play, you still need to do some testing and research to make sure it is installed right or you will end up like problems you have.
So check 3 things:
