How to route winch power cables to battery on 2012?
Hi,
I've got a Warn 9500 cti-s installed on my PSC Brawler Lite bumper, but I can't figure out how to route the wires safely on my 2012. I looked on the forum for write-ups on running the winch power lines, but my search-fu seems to be weak. Anybody have pictures/suggestions/links on how to run the wire for positive/negative to the battery in a 2012?
Thanks!
Thanks!
tagged...I would like to know too.
For now I ran my 2008 along the passenger side and zip-tied it to either the transmission or A/C high pressure line the around the fuze box. But it passed very close to a radiator hose and I worry about current drop when the power cable is hot.
Originally Posted by flienlow
Pretty simple really. I didnt tie anything off.
I got angry at the whole situation, and just pulled apart the winch, unbolted the positive/negative cables, got my own 2 gauge copper cable, crimped on copper bolt eyes (5/16", sized for 2 gauge wire) on one side of the cable, bolted that up to the winch positive/negative, then ran that how I wanted - marked where to terminate the wire, cut the wire, crimped on more copper bolt eyes, and then bolted them to the battery posts. I made sure to use shrink wrap tape where the copper eyes were bolted on. The wire itself has great insulation, but I did reuse the sleeve that was on the positive cable that came with the winch.
In hindsight, I should have routed the ground cable slightly differently, but it's great where it is. I'll try to remember to take pictures later, it's nothing fancy/not the best routing in the world, but it works, looks clean, and don't block access to anything in the engine.
PS - I used 2 gauge because that's what the winch uses stock, and I was only adding about 1 1/2 foot on the positive lead. 0 gauge would have been a pain to route.
