How to remove front speaker cover?
I replaced my stock speakers with Polk db351's. Here is the url for the specs at Circuit City (they had a special online that the store was able to match = (buy one set of speakers and get the second set half off):
http://www.circuitcity.com/ssm/Polk-...oductDetail.do
The sound greatly improved and I am very happy with the quality of the speakers. I must say that there is still a need for a sub. I am going to do this in time.
In addition to the speakers being great in sound quality, they are a marine grade speaker (perfect for a Jeep owner who may get a little "damp" from time to time.)
Have you updated all the other speakers as well?
Speakers replacement
I only had the stock Jeep speakers and not the Infiniti system. I am in the market for a small strong sub speaker. Do you happen to know where and what is out there? I did replace all of the 4 stock speakers, but left in the stock above dash tweaters.
I have an alpine 10" type s for sale.
I had a Kenwood KSC-SW1 powered sub in my 04 TJ and loved it so much that when the first one got drowned I replaced it. I'm going to put it in the new JK when I replace the factory head unit. Here is a link http://www.crutchfield.com/S-wbW7uVP...sp?I=113KSCSW1 I split my listening time between rock and country and like the fact that I can dial down the base if needed.
I also put in Polk marine rated speakers and I am happy with the upgrade to the sound. However the install into the dash is a PITA! Also had to modify the factory tweeter housing, but that only took a couple of minutes with a sanding disk on my Dremel.
Dash = Polk Audio DB6500 6 1/2" Componets
Roll Bar = Polk Audio DB 651s.
I purchased the above from Crutchfield since the DB6500's were on sale and they supply the mounting adapter brackets and wiring adapters for free.
Good Luck!
Good Luck!
