How to hook up amp and sub to factory infinity stereo system?
What's a good box to use for either 1 ten in. Sub or 2 tens? Also what wires do I need too hook up since I already have a factory sub? I don't think I'll use it tho? Thanks in advance
You can use a line out converter off the stock sub wiring...it really doesn't produce distortion from stock Infinity amp signal like you would get in other systems (maybe because it's so weak?). If you get one with a remote trigger, you can power on/off your sub amp with the system to save your battery. Sorry, no box recommendation as I used the stock sub enclosure with a JL 8W1V2-4 and it fits and sounds good for the music I listen to.
i used the same thing shakeyjake used for my 2-10's and it sounds great running the power wire from the battery to the back was the hardest part...keeping it away from the running gear and away from areas mud,rocks and tree branches can get into!
