How to fix Stupid 12v outlet
I am happily cruising OZ on a fun road trip and all of a suden the 12v outlet stops working so what do you do????
1. Check the fusses - not as easy as it sounds - there is a stupid diagram on the lid of the fuse box under the bonnet - it doesn't make any sense so don't even bother to try and figure it out!
Solution = check M36 (drivers unswitched outlet) and M6 (Passenger switched outlet) - they should be yellow 20amp fuses.
if the fusses are good then;
2. Check the voltage on the plug on the back of the 12v outlet - first remove top dash cover using a screw driver to pry up the rear corners, then remove the 2 screws at the top over the stereo, remove the lower panel- it just pry's off , rotate anti clockwise the 2 air vents to remove , then remove the 2 lower screws and pry of the entire facia - unplug the connector behind the dead outlet and measure the voltage - you will probably find between 12.7 - 13.5 volts on the plug and yet nothing comes out the cigarette lioghter socket!
Another triumph of Chrysler engineering - the 12v outlets - IMHO they are Cr@p they become loose where they are riveted together and then they will NEVER work again lol - good luck trying to get a replacement from jeep - when rang they were non available and the guy I spoke with thought they were between $90 & $150 LOL
After some searching (in Bairnsdale VIC) I found a very nice replacement that fits perfectly into the std jeep hole at SuperCheap auto for $9.00! - its only rated to 10amps but I only run my iphone / ipad charger and Waeco fridge (3-4amps) off it so 10a will do for now (until i can find a 20a one)
So before you tear out all of your hair searching for ghosts in the wiring - check the stupid 12v socket!
cheers Hunty
cheers Hunty
Button crazy! LoL
say for instance you have a mate in the front and he / she is small and in the back you have two 5'11 BBW models totalling 600lbs + a trailer weighing down the rear of your jeep that weighs say 200lbs on the tow ball - the combined 800lbs will cause your (USA) jeep to shine its headlights into the eyes of oncoming traffic! - so the factory switch controls a motorised headlight assembly and I get to choose which setting I want depending on Load! its pretty straight forward.
The color rockers are for my lockers (2x red - front and rear) the orange is a rear floodlight and the blue is for my ARB compressor
cheers Hunty
heres a post I placed on an OZI Jeep site explaing it better!
Hi Guyz
I wanted to add some switches to control;
Winch master power
Rear work Light
Arb Compressor
Front Spotlights
Map Lights
Fridge
CB GPS etc
I decided to install the daystar 4 rocker switch panel but I still wanted more switches - so on a recent SJC trip to the watagans I saw inside the trip leaders JK and noticed he had a nice commercial box installed above his mirror - that gave ma an idea - so (I'm guessing for a fraction of the cost)
I bought a second Daystar panel ($40 off Ebay USA including the switches fitted) and cut it down to fit the space above my mirror
Step 1 - Carefully measure the top panel and cut out a hole to install the daystar
Step 2 - cut down the daystar panel - as per pic
Step 3 - Test fit
Step 4 - Complete the wiring
Enjoy - Cheers Hunty
ps - I have burried the cb in the top panel now - looks heaps better!
12v Battery monitor
I mainly rely on my scan gauge to tell me the condition of my battery however it shuts down when i turn off the ignition.
I wanted to keep an eye on the voltage - I run a digital TV, computer, mobile internet, lighting and Waeco fridge when im out camping and wheelin (I am actually in my rooftop tent right now replying to your post) and as I havent yet installed a second battery and automation of the charging / change over system so untill I can afford them Ill just have to keep an eye on it the old fashioned way - the little plug in volt meter cost me $5bux off ebay
cheers Hunty
If you are having the same problem as the OP, you don't need to buy a replacement. Here is a fix for a 12v outlet that stops working because of poor rivet craftsmanship:
https://www.jk-forum.com/forums/jk-e...5/#post4034020
