How did you run 50" light bar wire
Old 08-30-2013 | 06:45 PM
JS1122's Avatar
Default How did you run 50" light bar wire
Looking to see how everyone ran their wire from their 50" light bar. Mines run into my drivers side door and down my A pillar but I'm having a leaking issue. Any ideas and photos would be appreciated.. Thanks
Old 08-30-2013 | 07:57 PM
Jkforlife's Avatar
Subscribed
Old 08-31-2013 | 07:54 PM
JS1122's Avatar
No one ??...
Old 08-31-2013 | 08:10 PM
firefighter53111's Avatar
Ran mine along side the mount I have down the A pillar. Then ran it under the front cowl then to the engine compartment. Sorry don't have any pics. Ill try to take some tomorrow.
Old 08-31-2013 | 09:02 PM
JS1122's Avatar
Thanks I'm just looking for a clean way to maybe change mine up
Old 09-01-2013 | 06:42 AM
Rico's Avatar
This is how I ran my wires also .....thru the cowl there is a space then I drilled a hole through firewall and used a grommet along with a black silicone
I have the delta bar but wiring is same ..the instructions said to run through the door frame and I also had leaks so went this route.
Old 09-01-2013 | 07:17 AM
Jersey_Devil's Avatar
I have an AEV snorkel so i was easily able to hide my wire...i just tucked it in between the snorkel and windshield
ID:	493795   Click image for larger version
ID:	493796   Click image for larger version
Old 10-03-2014 | 07:07 AM
Dlampe's Avatar
Anyone else?
Old 10-03-2014 | 10:29 AM
djparker19's Avatar
i have a soft top so i just ran it in the grove of the waterproofing to the a pillar, i might relocate it to run down to the engine compartment though
Old 10-05-2014 | 12:03 PM
maxspongebob's Avatar
I ran mine behind the A pillar bracket (Poison Spyder). My light is the VisionX light so there are 3 wires (+12, Gnd, Dimmer). I put 3 16 AWG wires in 4' section of heat shrink tube so that the cable was flat. Then, instead of using the supplied flat rubber gasket between the body and bracket, I used large round rubber washers. The washers are 1/8" thick, the gasket was 1/16". So with the washers there is a little bit more space. It turns out the cable and the washers are the same thickness. The wire runs all the way down and then under the cowl. There is only about 1/2" exposed where it enters the cowl.
Name:	2014-09-28 15.30.29.jpg
Name:	2014-09-28 15.30.40.jpg
Name:	2014-09-28 15.31.19.jpg
Name:	2014-09-27 23.25.26.jpg
Primate (12-07-2018)
