How can I wire 1 switch to operate 3 relays?
Thanks for the input
I'm still a little confused about splicing/connecting the 3 relays together to connect to the dash switch. Should I use a terminal or a wire nut? The dash switch is really just to flip the switch in the relay, so it's not going to draw much power(I think).
I really like posi-locks for my wiring needs.
h t t p://www.posi-lock.com/
Since the last 2 pairs of 55w lights (so 4 total) = 220w total, I probably only need one more 30amp relay instead of 2 relays & then I can just splice the 2 relays to the dash switch. Correct me if I'm wrong...
220w / 12v = 18.3amps so a 30amp relay should be fine
