High Beam Switch to activate driving lights INSTEAD of factory lights.
Old 03-30-2013 | 04:45 AM
  #21
JK-Ford's Avatar
Originally Posted by Kojack
Just wire the driving lights via a relay to your high beam circuit, but also put them on a switch. That's what I have done. So when I don't need my hid lights they are switched off.
This is what you are referring to. \/ \/ \/
However, like previously stated in this thread, there are certain conditions with certain Jeeps that will not allow this to work.
Old 03-30-2013 | 05:46 AM
  #22
Kojack's Avatar
Weird, I had three of my last jeeps wired like this. And I have daytime running lights too.
Old 03-30-2013 | 05:50 AM
  #23
Kojack's Avatar
I also have my hella fogs wired to the fog light switch on the stalk. So I can have my fog on and then my Hellas using the same switch.
Old 03-30-2013 | 07:34 AM
  #24
JK-Ford's Avatar
Then your DRL's aren't using the same OE circuit that your using to trigger the relay. If it did, it wouldn't work.
The above drawing /\ /\ /\ illustrates this. It's labeled as the "OE Circuit".
Old 03-30-2013 | 10:53 AM
  #25
Kojack's Avatar
Yes they do. My DRL is the high beam circuit. If I have my switch on for my hid, and my DRL are activated, my hid are on too. So I have them switched. On when I need them. Remember the relay only needs a very small amount of power to activate.
Wish you were close by to see how its setup.
Old 03-30-2013 | 12:54 PM
  #26
JK-Ford's Avatar
Ya I wouldn't mine seeing what you have.
Most / all relays have a threshold of opperation. And it's usually very close to the specified opperating voltage of the relay. That is why other people are having so much trouble with the PWM circuits and the DRL circuits.
Old 03-30-2013 | 02:27 PM
  #27
Kojack's Avatar
All I know is mine work great. They come on when I turn on high beams only. Or I can switch them off and use my stock high beam only. Good for different weather conditions. Same as my hella fogs. Come on with my stock fogs only, or I can switch them off and use factory fog only.
I'm in Canada so drl is a way of life. Worked around it no issues.
Old 03-30-2013 | 02:56 PM
  #28
3min3m2's Avatar
Or you could use a solid state relay to trigger the fog lights with the high beams.
