HID Retrofit Mod w/ Morimoto Mini H1's
Old 09-30-2011, 08:32 AM
mister ed's Avatar
definitely subscribed too. I've been looking at SimpleOrange's install and liked it. I currently have the Truck-Lite LED headlights but wouldn't mind making these and seeing the difference. Looking forward to pictures and updates!
Old 10-11-2011, 08:20 AM
mister ed's Avatar
anything new yet??? still curious!
Old 10-14-2011, 07:11 AM
Randonizer's Avatar
no not yet. i ruined pretty much both sets of headlights trying to get them apart. the chrome ones lens melted in the oven and the black ones wont come apart at all evne when heated
Old 10-14-2011, 08:11 AM
mister ed's Avatar
why are you trying to pull them apart??? Shouldn't you be able to just cut the back and make an adapter? Unless you are looking to paint the inner housing black? What temp were you putting them in the oven at and for how long? I've pulled plenty of headlights apart before but it was trial and error sometimes. Usually would do a low temp for 5-7 minutes at a time and check them.
Old 06-24-2012, 01:31 PM
J1nx93's Avatar
Any updates? Just found this thread and was going to use the Pilot's with H1 morimotos. Was wondering how they fit
Old 09-11-2012, 03:53 AM
blask06's Avatar
I'm running the morimoto minis. Here's an action shot.
Old 09-11-2012, 11:48 AM
spore's Avatar
To the OP, chopping up factory headlamps is a pain and I want you to finish this. I went this route:
https://www.pegasusautoracing.com/pr...asp?RecID=4851
Cut the appropriate sized hole in the middle of the disc for the projector lens (yes, it's entirely okay to have it exposed like that), drill 4 holes through the disc and run bolts into the projector housing.
I used the fx-r projectors from TRS. I've said in other threads that going retrofit projectors beats the crap out of any of the current headlight options for the JK.
They likely wont pass a state inspection, but be a kind motorist by aiming them properly and you're good to go.
I've since painted the discs black and sealed projectors in the back with a high temp (250F) aluminum ducting tape.
Name:	2010-05-24 21.26.36.jpg
ID:	364646Click image for larger version
Name:	2010-05-24 21.26.16..jpg
ID:	364645Click image for larger version
Name:	2010-08-22 08.43.47..jpg
Old 12-22-2012, 11:50 AM
efm-7's Avatar
I used the Pilot headlights that the OP was planning on using and it was definitely a pain in the ass. There's very little room behind the headlight in the engine bay, especially on the passenger side. So it's hard to seal up the back. Here's what I came up with:
The back enclosure is simply aluminium pizza pan and the bulb is sealed up with self-fusing silicone tape haha
I later ended up putting a small vent tube on it to try to help it equalize humidity inside and outside the enclosure because I noticed a bit of fogginess after running, which goes away after the bulb has been off for a while. Wierd... im keeping an eye on it - hopefully the vent helps.
Edit: I'd like to add that the output is simply amazing!!!
Quick Reply: HID Retrofit Mod w/ Morimoto Mini H1's
