HID problems
...funny!
Thats the same brand I made custom lights for my 3000GT with! I run Rigid Industries LED
"2x2 Dually's" in flood with a 10 inch "spot" bar in the center. I think these Bi-Xenon kits in my factory lenses will be the perfect compliment... Now to figure out a price effective HID/LED reverse light!
I ended up pulling my jdm hids on my jku cause I could never get them to stop flickering randomly on low beams. I believe my problem was with canbus and its pulse electrical system.
This is an issue of something being left out of the ballast.
Cause of the flickering and burnt out ballast are the day time running lights using less volts on the high beam circuit and the current is pulsed like stated before, It's best to use a relay kit for direct power from the battery and use use a AEV Pro-Cal to move DRL to the fogs, low beams or markers
Just switch the ballast from the one that working to the one that isn't working... If it lights up then it's the ballast, if it stays out and the other one lights up still then it could be the bulb or a loose wire
