Help needed with uconnect and iphone....spotify, iheart radion etc...
using my iphone 4 and spotify of iheart radio. I cant not get this to work either bluetooth or using usb cable... Anyoen have similar problems or have a fix? Also sounds as if the stock deck can not handle the steaming...
Thanks in advance
chris
Thanks in advance
chris
Hey Chris,
What radio do you have? Also what year is the vehicle? Thanks
Same thing happens with Pandora or listening with. An audiobook.
Basically you've got to trick the iPhone and radio.
Let me explain.
When you turn your Jeep on your iPhone syncs up via Bluetooth and u connect
You have to start streaming music and then start your radio app.
Now on the 130 RES you don't have touchscreen like the mygigs
Maybe it was a coencedence or not but I was able to press the button on my steering wheel that looked like a play button on a CD player and it would work
The other way to do it with the USB cable is once your app starts playing go into your airplay icon and make sure it is set on dock cable instead of u connect.
Let me explain.
Chris,
You have a 2011 Wrangler with the RES radio, do you know th ebuild date for the vehicle? (there should be a tag on the drivers door, look for code MDH).
Also have you hhad (or done) the Uconnect SW update that came out to the dealers in 6-2011? This is a TSB that can be done by either the dealer or by you if you'd like to do it.
