help with mygig
help with mygig
hey there i just recently bought the mygig and i hooked it up tonight and for some reason everytime i start the jeep the mygig opens its very annoying anyone know what i might of done wrong? thanks.. also when i was taking the panels off a metal clip fell off anyone have any idea of where to get those?
Not sure about the opening issue but the metal clip is most likely from the top dash panel. There are two metal clips that are pressed onto the plastic tabs that snap it into the dash in the back. Take your top panel off and see if one is missing.
Try resetting the unit by taking off the negative battery cable and turning your lights on for a couple minutes. Turning the lights on will drain the residual power from any capacitors in the system.
