help me troubleshoot my lights!
Hey all thanks in advance for the help.
I just installed a pair of hella rallye 1000s on my bumper. I have installed a lot of lights on cars before and this install went smoothly... or at least i thought. Everything works great with the engine off. The lights come on with the high beams and off with the low beams and so fourth. However as i found out tonight this is NOT true with the engine running. With the engine running the hellas will flash on quickly then off again with the high beams. they will then stay off until you cycle the lights and flash again. They will stay on for about a half second before shutting off. Could this be a bad relay? the only thing that is different is the alternator so could the increase in current cause the relay to open somehow?
cheers
Steve
X2 I wired up my hella 500ff's to an independent switch, mine was for the reason that I wanted to be able to run them high, low, or just by themselves if I really wanted to, people use alot of different setups but I got a daystar lower panel and I came out pretty clean, good luck!
