Help with LED headlights......
First post here, been lurking for awhile but bought the wife a '14 JK on 35's a few months ago and have been tinkering with it since.
Anyways, picked up some offroadledbars LED headlights, and have had issues since day one. The main thing, is that in park, or in gear *with the e-brake on*, the lights work perfectly. Running, halos, manual on, etc. But, as soon as you put it in gear, and the e-brake is off, the lights can not be switched on/off/runnning/etc. as should. They will come on, but certain led's will only be on, and you can't control them as you should be able to. I've tried to contact offroadledbars and that's been useless, so I figured someone on here must know! TIA guys
Brian
Brian
