Help with finding Relay
Old 10-28-2008 | 01:22 PM
jeepnyak's Avatar
Default Help with finding Relay
I had the dealership install the mopar-hella windshield lights. I am adding more lights. I can't find a relay. Just a fuse. Where is yours located? What is the amperage? Is it in the fuse box? Good thing that I'm bald or I'd be pulling my hair out.
Old 10-28-2008 | 01:45 PM
Littlejon's Avatar
According to the image in the PDF for the instalation from Mopar it looks like the relay should be in the dash right behind you steering column.
Old 10-28-2008 | 06:44 PM
jeepnyak's Avatar
does it say anything about amps?
Old 10-28-2008 | 07:25 PM
Littlejon's Avatar
It didn't say anything about the apms on the relay. I pulled it up on the Hella site thinking it would say, but nothing.
Old 10-31-2008 | 08:29 PM
jeepnyak's Avatar
anybody locate their relay for the mopar hella's?
Old 10-31-2008 | 10:37 PM
poppakristof's Avatar
Check under the dash, driver side, under the steering column.
It should have been tucked under/behind the driver woofer speaker.
Your going to have to get into a yoga pose to reach it.
It will be a block with 4 sets of wires shooting out of it.
There is a hole so the relay can be mounted but it never is.
I added 2 sets of these to mine.
The block by the battery should be the fuse.
Link to Installation Instructions
Old 11-06-2008 | 11:57 AM
jeepnyak's Avatar
thank you
Old 02-09-2009 | 04:09 PM
jeepnyak's Avatar
found it! under the steering wheel, 30 A
Old 02-09-2009 | 05:07 PM
ronjenx's Avatar
OEM Wire harness for windshield lights:
Relay 30 amp.
Fuse 25 amp.
The instructions show how to hook up a second harness to the first, too.
Each harness will have its own relay and fuse.
Old 02-10-2009 | 04:13 PM
jeepnyak's Avatar
there was a connector coming off of the relay. I was wondering what that was for.
