Help with ARB switch
Old 03-25-2009 | 06:45 PM
Preciousmetal's Avatar
Default Help with ARB switch
I'm hooking up a ARB switch and just want to know which wires are good to hook up for ignition on and dash illumination, these are the two wires with the diodes . The color of the wires will help very much. Thank you very much for your help!!!!!
Old 03-25-2009 | 08:07 PM
I'm sorry for this I did find a thread on this. I guess I'll hook it up to the lighter and on the 14 pin connnector second pin across from the black wire. Just wish I knew for sure what the color of that wire is for sure. I can firgure this out I just wanted to save some time and see what you all did with your wiring on this. Some of you come up with better setups than using the lighter for things.
Quick Reply: Help with ARB switch
