Help!
I have got all sorts of light coming on... It all started a couple weeks about when I replaced my track bar... Put the new one one to help fix the death wobble. After that was done I noticed that my steering wheel was not aligned, It was slightly tilted passenger when traveling straight. I didn't fix this right away because I had a new tie rod and drag link in transit to my house. The next time I drove on the freeway I had my ESP/BAS and Traction control lights come on. On Thanksgiving I had 2 codes pop up with a check engine light. Codes are P0430 and P0158. I look at my O2 sensor for the P0158 code and there is a frayed wire so I think I will replace that here soon. Yesterday I put on my new tie rod and drag link and straightened the steering wheel out. Today I had the ABS light come on. Good news is I think I fixed the death wobble.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
I'll ask the obvious....when you installed the new TR and DL, you recentered the steering wheel correct? Looks like the traction light is unrelated to the OBDII codes which are O2/cat related. Do you have a scanner that can dig into the ABS module? Most diagnostic phone apps can get in there. When the ABS light comes on, it's storing a code down in that module, and it will give you some reference to go on from there.
