Hella Lights, blown fuse or bad swtich?
Ok, so I moved my Hellas from windshield to bumper and they are not coming on. I had to lengthen the ground wires from the lights so that could be an issue but I doubt it. The grounds are good, the switch would illuminate at one time but won't now. Any thoughts? how do you tell if the fuse is bad? or if the swith is bad?
OK, tested the harness by using some scrap wire to touch the red and black together and they worked, so diagnosis: bad relay. Now I know what I need. Thanks for the assistance and the great help by Casey Callaway at Hella
Glad you resolved your issue. We have had quite a bit of snow. But it's been scattered. North some times. South sometines. Then central sometimes. Calling for snow south and central today.
