Hella 500s Stopped Working
#21
What connectors do I need? The wiring seems fine, it's just the 4 pin relay by itself that pops off the female connector with the 4 wires attached to it.
#26
The red wire should be coming from the + battery terminal, so yes it should be 12 volts.
Here is a description of the Hella wiring...
Lights:
Blue wires to ground on frame
Black wire to relay
Relay:
Red wire to battery + terminal
Black wire to lights
Blue wire to ground on frame
Yellow wire to switch
Switch:
Yellow wire to relay
Green wire to a 12v source. (I connected to the fuse box using a fuse tap.)
Lights:
Black wire to relay
Relay:
Switch:
#27
It's a miracle. Finally got it working. Turned out the super cheap fuse connector it comes with somehow went bad, so I cut it out, popped in a new one with a 15 amp fuse and it works. What a pain!
At least it's working now! Thanks for all the help.
