Hella 500 inside the grille
Hello, I would like to know if its possible to fit a pair of hella 500 behind the grille of a 2014 wrangler sport like some truck guy do. If not does its possible to mount them flush to the bumper like the stock one on a steel build bumper. If somebody build a bumper with those foglights flush mounted show me some pics. Thanks
Check out « Rock-Slide Engineering Rock-Slide Engineering pricey but soiled ,you get what you pay for.
Interesting ?? But not exactly what Im looking for. Does its possible to cut the stock bumper and fit them in the same spot as the stock one ? Does the stock wiring can support them instead of stock one ? If I build a steel bumper does it will fit between the front frame rails ?
ah I don't think there's room , a smaller diameter sure , if i remember right the stock fog's almost fill the inner steel .
I did do the rear bumper with swap meet fog's. i believe there off a 80's gmc .
If you remove the stock inner steel bumper and replace it with a fully steel builded bumper does it will fit between the chassis frame ? What is the distance between the two frame rail (where the inner steel bumper is bolted ?
Sounds like your looking for something like this from Ansani designs
I sincerely hope English is not your first language.
