Heated Seat Dash Buttons
Hey guys, long story short I am getting my seats redone and having heated seats added. I asked the guy doing the custom work if he could put the buttons for the seat heater controls in the stock location using the stock buttons. He said he could if I brought him the stock buttons, the part that plugs into the back of the buttons that connects to the wires, and the wiring diagram. OK, does anyone have any part numbers, wiring diagrams, or perhaps a website that could help me acquire these things. Any help would be much appreciated.
Found these switch's that mount to the dash. Don't have a diagram but I know one comes with the heated seats.
http://www.sportsimportsltd.com/ilsehehirosw.html
Found this diagram on Quadratec.
http://www.quadratec.com/Assets/Installation/107636.pdf
h t t p://jeepparts.mopar.com/jeep/wrangler-parts.html
or Google the "Mopar E-Store", once you are there you can look up nearly all parts including switches. Once you have the name of item you can search for it and it usually comes up with the Part number for you.
Then you can go to the dealer or look up a mopar wholesaler online for less.
The 2011 JK heated seats are LIN and CAN data-bus controlled and require programming. Likely possible given some work.
On the 2007 - 2010's, the switch pod is # 5 below:
04602511AH
Electrical
Switches
Switches - Instrument Panel
SWITCH, Pod
Headlamp Leveling System ,Electronic Stability Program
04602512AH
Electrical
Switches
SWITCH, Pod
Tru-Lok Front & Rear Axles ,Locker Rear Axle ,Headlamp Leveling System ,Electronic Stability Program ,Front Disconnecting Stabilizer Bar
04602694AG
Electrical
Switches
SWITCH, Pod
04602695AG
Electrical
Switches
SWITCH, Pod
Tru-Lok Front & Rear Axles ,Locker Rear Axle ,Front Disconnecting Stabilizer Bar ,Electronic Stability Program
04602511AH
Electrical
Switches
SWITCH, Pod
04602512AH
Electrical
Switches
SWITCH, Pod
04602694AG
Electrical
Switches
SWITCH, Pod
04602695AG
Electrical
Switches
SWITCH, Pod
