Headrest monitor help
Hey guys
I put the 7" alpine screens in my headrests. Just wondering from those that have done a similar install. Any tips on running the wire down the seat back?
Anyway to get the grey plastic "collar" that the posts go into off the seat?
Any tips would be awesome
Thanks Jesse
Thanks Jesse
Hey guys
Thanks Jesse
Thanks Jesse
I was able to feed the wire through the back of the seat. I pressed down on the material under those collars and fished the wire. It was surprisingly easy.
I'll give that a shot
I had them installed for a few months and haven't even tried to run the wires. I thought it was going to be a giant hassle.
Thanks for the help.
Jesse
Jesse
Any pics of the install? My kids would love for me to do this, but I've been afraid of how it would look. I'm not interested in changing out the entire headrest.
I ended up getting the entire replacement headrests that have the Zip up flap. That way you cant tell they are there unless they are opened. The wire on those runs down through the post and I fished it down through the seat and through the center console and then tied into the power port.
I did this in mine....and also re-skinned my seats with Katskin leathers at a later time. So, I'm kind of familiar with the seats.
Feeding a wire up from the bottom and through that headrest post hole is not an easy task. Trust me, that's how I did it the 1st time before I did the Katskin leather install. You'll spend all day with a snake trying to get it to bend in the right position.
Here's how to do it. At the bottom of the seat (where the seat folds) is a plastic J hook. Take a flat head screw driver, slide it along the plastic and unhook it. This will separate the front from the back. Now just roll the seat fabric up like you're taking off a condom. On the inside of the seat fabric there is just velcro on the front holding it in place.
Now run your wires anyway you want and slide it through the top post hole. Do the reverse to re-assemble. The hardest part will be trying to refasten the J hook at the bottom of the seat. I hooked it on one side and then used the flat head screw driver and slid it along.
Thankfully, with the Katskin seat skins, they don't use that damn J hook which is a bitch to re-hook. They use zippers instead. Infact.....do yourself a favor and buy a set of Katzskin leather skins while you're at it and throw that cheap fabric crap away. If you go ahead and do that....be sure to add some heated seat pads while you're at it. That's one thing, I wish I had done when I had the skins completely off before I put the leather on.
