Headlights & Domelights
I looked around and couldn't find a thread on this.
Is there a way to shut off the automatic headlights when you unlock your JK? Or a way to keep the dome lights from coming on when you shut the engine off?
I bought my 07 JKU used. No manual
Manually turn your lights off before shutting the engine off, this will override the timer..if you flick them on and off twice before shutting the engine off it should override the dome light staying on...you can also go to the dealer and have them shut this feature off but at a charge...i'm not sure how much$?
Edit sorry didn't notice it was for when you unlock with remote...I don't have power anything..windows, locks,ect. But you should be able to do it but may require the dealer in that case
