Headlight very loose
My driver side headlight is very loose, I just installed the new truck lites and the headlight is not tight and very wobbly. I tried tightening it tonight but there isn't anything I can do to tighten it. I know there are 2 tab like things that hold the headlight in place but they are both very loose.
What have other people done in this situation?
I actually took some electric tape and wrapped the outer lip that the ring sits against. 2 wraps of tape was perfect, this fit nice and tight now. I would recommend doing both, my right side one was tight at first, then after I pulled them to put in the anti flicker harness it was loose, so I had to go back and wrap it as well.
I will defiantly be putting some tape on the ring to make it more secure.
But I think we are talking about different things being loose, the light is angled down right now I tried angling it up to match the other light which is not loose but I can't figure out how to make the light not wobble. There are plastic pieces that hold the housing in place which the bezel screws into. That is loose and I don't know how to make it not wobble
I will take pictures sometime soon so I can explain it better.
If it's the actual bezel that's moving out may be broke like mine was...i just use rtv to glue it lol
Sent from my obama listening device
