Headlight ?
Headlight ?
Ok so I came across some cheap h4 e codes and was wondering, could I use the stock light bulbs with the e codes, is it just a quick turn and switch them out or would I have to stick with the h4 bulbs the lights come with and make/ buy a harness. I can post a pic when I get back to the office, but it dosent look like one solid piece and should be switchable. Any thoughts, suggestions, ideas.
Thanks
Thanks
You will have to modify the wiring to attach to the h4 bulb. You also may find that the lens is slightly thinner than the factory one, to fix this I ran a bead of silicone on the inside of the retaining ring, let it dry and then install as per normal. I used IPF headlight lenses and they were a huge inprovement.
